Today in the shop (working on a birdhouse)
Back in this thread:
http://www.shopsmith.com/ss_forum/viewt ... od#p247267
I was working on a birdhouse and using the GWSS to make the cuts. Since I had no idea of the angles and since I wanted to do a bit more on the project and I want to see how the GWSS might work for angle cutting........ This is for the bottom of the birdhouse and yes it doesn't really need to be done but it was an excuse to play.
So I guess most of you know that sometimes for non critical times you can simply put the bottom of your angled piece that you want to match on the main table then tilt until the angle of the table lines up with the angle on the work piece. Except in this case the secondary angle doesn't let you do this well. So time for a little trick of the trade.
Then you can transfer the angle to the table/blade:
Now using the line I put on the work piece I used the GWSS to make the cuts.
The set up:
And the results:
For a birdhouse this was more then satisfactory.
wood1studio
Re: Today in the shop (working on a birdhouse)
Post by wood1studio »
Deleted by Moderator
moggymatt
Post by moggymatt »
Since Wood1studio is going to be on the high seas, is that considered pirating the thread or still highjacking?
Reible,
Are you making that bird house for a specific bird species?
Paul B
wood1studio
my apologies, I meant no disrespect... :)
rpd
Post by rpd »
wood1studio wrote:my apologies, I meant no disrespect... :)
Welcome aboard.
There is a group on Facebook for selling, buying, trading, Shopsmith related items. :) https://www.facebook.com/groups/298235127282459/
moggymatt wrote:Since Wood1studio is going to be on the high seas, is that considered pirating the thread or still highjacking?
Reible,
While the house looks large and is large on the outside it is really for small birds. The sky light needs to be shaded so the front of the roof is extended. I also hope to add a wire grid or something to keep other critters from raiding the nest. We have had raccoons do that a couple of times so a new design this year.
