Setups in pictures
Setups in pictures
More of my Flickr collection that is moving here. The first couple are just general setups, I like the one with the ruler as it reminds me just how large the front table can get with very little effort.
[ATTACH]2952[/ATTACH]
[ATTACH]2953[/ATTACH]
[ATTACH]2954[/ATTACH]
The later photos are of my secret setup tool... but it has been posted here and else where before so the secret is out. They are in the next two post of mine.
- su1.jpg (156.84 KiB) Viewed 2112 times
- su2.jpg (144.72 KiB) Viewed 2111 times
- su3.jpg (139.02 KiB) Viewed 2112 times
[attach]2955[/attach]
[attach]2956[/attach]
[attach]2957[/attach]
[attach]2958[/attach]
- sus1.jpg (155.38 KiB) Viewed 2108 times
- sus2.jpg (86.17 KiB) Viewed 2110 times
- sus3.jpg (124.8 KiB) Viewed 2104 times
- sus4.jpg (150.82 KiB) Viewed 2126 times
[ATTACH]2959[/ATTACH]
[ATTACH]2960[/ATTACH]
[ATTACH]2961[/ATTACH]
[ATTACH]2962[/ATTACH]
And that should do it for these sets. If you have questions keep them to your self.... no no, please just ask.
- sus5.jpg (145.93 KiB) Viewed 2104 times
- sus6.jpg (130.87 KiB) Viewed 2098 times
- sus7.jpg (139.45 KiB) Viewed 2099 times
- sus8.jpg (135.73 KiB) Viewed 2097 times
fieryknight
- Bronze Member
- a1gutterman
fieryknight wrote:What a great idea, hadn't thought of using it this way. Thank you.
fieryknight,Keep in mind that before you use the sheetrock square to line up the tables, your table surfaces have to be adjusted correctly. Do you mind setting your public profile to show where you are from?
Tim
Ed,
About the bracket you have attached between the main table and the auxilliary tables...where did you get it. I checked the Shopsmith catalog and couldn't find it. I have a 510 but that bracket isn't shown in the 520 upgrade. I have floating tables, poles and extension legs but have to mount the floaters off-set from the main table.
Thanks.
P:D
Thanks.
P:D
Serial #12-21-93 - 510 with Bandsaw and 4" Jointer:)
Greenie with Jointer and Jigsaw:D
Hi,
Check for extension table brackets 555997.
pascalore wrote:Ed,
Thanks.
P:D
befuddled
anyone got a pic of the bracket itself? I'm looking at the pics and still can't quite see how this works, but I DO like the idea of infeed/outfeed tables using my extra floaters.
https://forum.shopsmith.com/viewtopic.php?p=50197&postcount=20
But for more reading check out the whole post.
https://forum.shopsmith.com/viewtopic.php?t=4437
This might be a bit on the far side for some of you, but hey that is where some of us live and play.
