Ball Joint
Docdare55
Ball Joint
Post by Docdare55 »
I recently bought a new to me 510 after I lost my original 34 year old 500 in a fire. On the carriage and the right tail piece mounted with screws to the bases is a small 3/8 to 1/2 ball joint I don’t recognize. Searched my documentation can’t find out what it is, or maybe I’m missing some pieces. THOUGHTS?
HopefulSSer
Re: Ball Joint
Post by HopefulSSer »
If I were to guess I'd say they're probably part of a lift assist
Mark V 510 51-014654
edma194
Re: Ball Joint
Post by edma194 »
Perhaps the Gas Spring Table Raiser - https://martins-supplies.co.uk/presta/d ... v-510.html
That would attach to the carriage and the casting.
Re: Ball Joint
The Gas Spring Table Riser for use when in Drill Press Mode is what I believe Docdare55 describes attached to his Mark V. Shown below.
_
Gas Spring Table Riser 556335.jpg (43.44 KiB) Viewed 17000 times
Not the Lift Assist for raising to the Drill Press Mode as shown in the picture below.
_
Lift Assist post 1972.jpg (13.63 KiB) Viewed 17005 times
As you can see the Lift Assist has the Threaded Ball Studs attached to the brackets for the ends of the Gas Strut. The Gas Spring Table Riser, that Ed provided the link to, uses a gas strut between the Carriage and the Base to help adjust the Table Height for Drill Press Mode.
Those are the only two accessories I can think of right now that have ball joint studs for the Mark series tools.
HopefulSSer
Re: Ball Joint
So it's a lift assist, not The List Assist. ;)
Docdare55
Re: Ball Joint
Post by Docdare55 »
Thank you all for the quick replies!
gracej45
Re: Quick Release for Lift Assist
Post by gracej45 »
I'm 80 years old with a back problem (6 back surgeries) so I bought the PowerPro Lift Assist for my new Mark 7 (1 week old). Everything went great except for the "Quick Release for the gas cylinder" doesn't want allow you to pull the slide back to install or remove it. Has anyone had problems with it. Already been to YouTube, talk with Mike Young. Also had my neighbor try to move move the slide on the quick release with no luck.
Jon
larryhrockisland
Post by larryhrockisland »
gracej45 wrote: Tue Apr 22, 2025 7:57 pm I'm 80 years old with a back problem (6 back surgeries) so I bought the PowerPro Lift Assist for my new Mark 7 (1 week old). Everything went great except for the "Quick Release for the gas cylinder" doesn't want allow you to pull the slide back to install or remove it. Has anyone had problems with it. Already been to YouTube, talk with Mike Young. Also had my neighbor try to move move the slide on the quick release with no luck.
Jon
Maybe this will help. viewtopic.php?p=309025#p309025
Larry Hargrove
Rock Island, Ok
1957 Mark V 500 (350389)
1953 10ER
Another 10ER
Bandsaw 2012 Jointer 2012
