Shopsmith Mark V, part 75 came loose
johnhubbard46
Post by johnhubbard46 »
Hi All,
My 42 year old Mark V worked perfectly until a small piece, part 504187, loop, retaining, reference # 75 on the parts diagram, came loose.
Does anyone have information on how it is reattached or how it looks when reattached?
Mine may be bent as the two legs are not parallel now. Is it supposed to have parallel legs?
Thanks for any help.
John Hubbard
A side question -- can an image be added to a post? This is my first post to the forum. Thanks.
SteveMaryland
Re: Shopsmith Mark V, part 75 came loose
Post by SteveMaryland »
For quick reference, this earlier thread might be the best one to look at:
viewtopic.php?p=316191#p316191
and another:
viewtopic.php?p=182375&hilit=504187#p182375
and another:
viewtopic.php?t=1843&hilit=504187
This is an important component. Others here on the Forum will respond soon to explain how this part is installed.
johnhubbard46 wrote: Sat Nov 16, 2024 12:50 pm Hi All,
John Hubbard
A side question -- can an image be added to a post? This is my first post to the forum. Thanks.YES
br549
Post by br549 »
johnhubbard46 wrote: Sat Nov 16, 2024 12:50 pm A side question -- can an image be added to a post? This is my first post to the forum. Thanks.
There is a "sticky" thread near the top of the Community Forum that explains the process of attaching pictures. It was started before the forum changed some of it's options, but has been updated as the options changed.
Here is the part
_
504189 Control Sheave Retaining Loop.jpg (20.68 KiB) Viewed 1897 times
Here it is in position.
_
Headstock B e8.jpg (258.68 KiB) Viewed 1897 times
This headstock needs work. :eek:
johnhubbard46,
Sorry it was a quick answer before. I was getting ready to leave. Post again if you need additional information.
Also, Welcome to the Shopsmith Forum.
