Kreg Bandsaw Fence
shydragon
Kreg Bandsaw Fence
Post by shydragon »
I just received Shopsmith's latest ad, for the Kreg Bandsaw Fence System. I've been thinking about it and was wondering if this is worth the purchase? Any thoughts from others that might have this system?
Thanks
Pat
Oregon
1992 SS 510, 11" Bandsaw on power station, 4" jointer, Pro Planer, Incra Miter 2000, Incra Ultimate Fence Router Pkg, Grizzly 6" Parallelogram Jointer.
8iowa
Post by 8iowa »
I'm thinking about it also. It looks as if it might improve resaw capability. I presently heve the deluxe fence that locks on both ends.
ldh
Post by ldh »
shydragon wrote:I just received Shopsmith's latest ad, for the Kreg Bandsaw Fence System. I've been thinking about it and was wondering if this is worth the purchase? Any thoughts from others that might have this system?
Thanks
Pat,
I have the Kreg Fence on one of my saws and it works great. The deeper front rail is handy, but I don't know if I am sold on it being any better for resaw.
ldh
[ATTACH]7903[/ATTACH]
[ATTACH]7904[/ATTACH]
john
Post by john »
Pat:
I bought one a couple of years ago and like it for sawing, but I found a couple of drawbacks from my point of view.
First I find the portion of the fence that sticks out to the left can be a safety hazzard in my small space. (see IDH's picture) The second is that I find it made it more difficult to remove and replace the band saw on my 510 as te fence adds weight and gets in the way. Of course this is no problem if your saw does not have to be moved.
Would I purchase it knowing what I now know? The answer is yes. It has been a good addition to my shop.
Godd luck with your decision.
John
shydragon
Post by shydragon »
Idh, looking at your photo, do you have to remove the rails to replace your blades?
Pat
Oregon
ldh
Post by ldh »
shydragon wrote:Idh, looking at your photo, do you have to remove the rails to replace your blades?
The rail bolts just to the left of the table slot and you have enough room to change blades without having to remove it.
ldh
[ATTACH]7907[/ATTACH]
ryanbp01
Post by ryanbp01 »
Will the resaw guide work with the Shopsmith bandsaw fence?
BPR
wlhayesmfs
Post by wlhayesmfs »
Pat in your second picture that is quite a resaw set up. Is the stacked feather board system somehow mounted to the extention piece of the table? Looks like it has an adjustment on the side. Any chance of seeing that closer or getting a set of plans. I am getting into resawing and new at it but sure is a better way to get some cheaper wood for turning pens and small projects.
thanks
Bill :)
Broken Arrow OK
ldh
Post by ldh »
ryanbp01 wrote:Will the resaw guide work with the Shopsmith bandsaw fence?
BPR
I am not a fan of the Kreg Resaw Guide, but many of the members of the forum have built similar guides to fit the SS fence. I am sure someone has modified the Kreg Guide to work on the SS fence and will jump in here with some pics. I modify the guide bearing setup on my saws and I have had the best luck with the regular SS fence for resawing.
ldh
ryanbp01
Post by ryanbp01 »
The reason I asked is that I have an older SS bandsaw which I'm updating with the aluminum table. I do have the bandsaw fence and while I do like what I see with the Kreg system, I don't know if I can justify the cost of the whole system but maybe I could use just part of it.
BPR
