What a difference a day makes!
Before
[ATTACH]8873[/ATTACH]
[ATTACH]8874[/ATTACH]
[ATTACH]8875[/ATTACH]
After
[ATTACH]8876[/ATTACH]
[ATTACH]8877[/ATTACH]
Refurb of my Jointer...
- paulrussell
- Before1.JPG (151.75 KiB) Viewed 4548 times
- Before2.JPG (183.39 KiB) Viewed 4548 times
- Before3.JPG (233.28 KiB) Viewed 4545 times
- After1.JPG (215.56 KiB) Viewed 4542 times
- After2.JPG (194.33 KiB) Viewed 4542 times
Paul
520 PowerPro, Planer, Bandsaw, Jointer, Belt Sander, 20" Scroll Saw, Dust Collector, conical disc
Also: 3D printers, and a homebrew CNC
- paulrussell
and finally ...
[ATTACH]8878[/ATTACH]
I realized today that I'm also missing the depth adjustment knob.
Overall I still need a blade guard, coupler hub, support tubes, and the depth adjuster knob.
- After3.JPG (243.75 KiB) Viewed 4541 times
Paul
- paulrussell
The cut/scrape on my hand caused by the corner of a cutter is healing nicely. In a related thought I've decided to go with the updated safety cover/featherboard. Routers, shapers, and jointers have always made me just a touch nervous - probably a good thing.
Paul
- tom_k/mo
Paul, nice job on the refurb/rehab. What method did you use for the rust removal?
- paulrussell
Thank you! I think it actually looks a bit better than the pics because there is zero rust remaining & for some reason it looks otherwise in the pics.tom_k/mo wrote:Paul, nice job on the refurb/rehab. What method did you use for the rust removal?
As for rust removal: I tried the electrolisis method overnight on the upper plate, and although it bubbled, my results were poor. I think my vat was sub-optimal.
Small parts & the fence got a bath in evapo-rust. The unsuccessful table & its brother were given my tried & true rust removal method: a combination of wire brush, steel wool, emery paper, and scotchbrite pads powered by elbow grease and the occasional dremel tool.
A couple particularly nasty nuts were replaced from my junk box. I opted for a dark grey Rustoleum hammered finish. I am MUCH happier with the dark than I was with a silver hammered I tried earlier this year.
To me the dark grey looks better than the original battleship grey, even though the jointer is sorta shaped like a battleship to begin with (and weighs nearly as much),
Paul
The refurb looks great, Paul!
Heath
Central Louisiana
Central Louisiana
I always think of an Aircraft Carrier when looking at the jointer!;)paulrussell wrote: . . ..
- paulrussell
