Bracket placement
ryanbp01
Bracket placement
Post by ryanbp01 »
Regarding the bandsaw, where is the recommended spot to mount a bracket for a utility light?
BPR
BigSky
Post by BigSky »
ryanbp01 wrote:Regarding the bandsaw, where is the recommended spot to mount a bracket for a utility light?
BPR
I am certain that "someone" will answer this question but without knowing what light you are attempting to hang, I don't know how.
The best answer that I could provide would be "hang it where it will provide the light needed and be easy to turn on/off".
I would not attach it to the plastic cover!!
MarkFive510
tom_k/mo
Post by tom_k/mo »
I attached mine to the back side, just below the hub for the upper wheel. It works well. The only thing I did was change out the self-tapping screws that came with the mounting base with a set of machine screws & nuts.
[ATTACH]12803[/ATTACH]
ryanbp01
Post by ryanbp01 »
BigSky wrote:I am certain that "someone" will answer this question but without knowing what light you are attempting to hang, I don't know how.
A Shopsmith utility light.
BPR
BigSky
Post by BigSky »
I don't have one but maybe this thread will help.
MarkFive510
I bought one of these lights a while back. Like Tom, I put a mounting bracket on the bandsaw. However, before doing this I mounted it in any "T" slot available. In fact I still mount it in the saw table, the rip fence, or the bandsaw rip fence when using drill press or strip sander.
In order to mount the light in the "T" tracks, you'll need one of these. http://www.shopsmith.com/ownersite/itemfind.htm?item=521787&Submit=Find+Item I know it is expensive, but it sure is handy!!!!
You can also buy extra mounting brackets and attach them to any SPT you have. BTW, the mounting bracket comes with a drill bit and self tapping screws. Also, instructions on best places to mount the bracket(s).
fiatben
I want it
Post by fiatben »
Tom,
Where did you find that great graphic of the bandsaw????
fiatben wrote:Tom,
My guess is he 'created' it!;)
joedw00
Post by joedw00 »
Mine is mounted on the headstock, and works great.
Joe
Being a VETERAN is an honor
Being a GRANDPA is priceless
tom_k/mo
Post by tom_k/mo »
fiatben wrote:Tom,
I drew it up in SketchUp. It's available in their 3D Warehouse if you'd like a copy.
