Everything Mark 5 / V - Technical info, documentation, links
mickyd
Post by mickyd »
With the volume of various threads and posts related to technical info on the Mark 5 / V machines, I saw it fitting to start a thread that can compile 5 / V related information in one place. It will either contain the info directly or link out to appropriate areas. Informational commentary and dialog is welcome. To keep the thread on topic may be difficult. We'll see how this works.
Troubleshooting and repair: Restoration Threads - mickyd, mikelst, ddvann79, fiatben General Information
  • Interesting machine modifications
  • Miter gage - Adding one to your extension table courtesy dusty
  • Model 500 table height adjustment handle knob conversion over to the circular style
  • Installing 505/10/20 Crankon 500 table lift
Sunny San Diego
mickyd
Post by mickyd »
Sunny San Diego
mickyd
Post by mickyd »
reserved for stuff
Sunny San Diego
mickyd
Post by mickyd »
reserved for more stuff
Sunny San Diego
mickyd
Post by mickyd »
reserved for even more stuff
Sunny San Diego
heathicus
Post by heathicus »
Admin, if you're reading this, can you make this thread sticky? And then delete this reply?
Heath
Central Louisiana
robodad
newbie with a greenie.
Post by robodad »
I have an A-headstock greenie from my dad. I use it infrequently but when it kept tripping the breaker, and after cruising this forum, I decided I needed to lubricate. The motor and belts were replaced about 10 years ago.
In drill press position.
Motor dropped.
Control sheave removed(and drive belt). Belts in decent shape.
No lubrication holes except on floating sheave(as expected).
Not a lot of sawdust inside. Overall things look pretty good except porkchop which is not the subject of this thread.
Poly V-belt (or Gilmer) in place.
After I finished lubrication (I am still in drill press position) I manually turned the main spindle shaft clockwise and it is smooth.
However, counter clockwise it binds. I know that this is a forbidden movement when the drive belt is in place and would cause binding. But what does counter clockwise binding indicate with drive belt disengaged ?
I can't seem to find a forum answer.
Hope its not the bearings!
Thanks to forum members for taking time to share.
I hope I am in the correct thread!
onevw
how hard should it be to turn the thickness planer adjustment
Post by onevw »
I got this thickness planer with the cast alum round handle used to adjust the plate. It is hard to turn, I lubed the lead screws with bo-shield a light lubricant usually used for Alum. But is still very hard the turn handle. Not sure how hard this should be. And help will be appreciated.
Thanks RICK
Hobbyman2
Re: how hard should it be to turn the thickness planer adjustment
Post by Hobbyman2 »
onevw wrote:I got this thickness planer with the cast alum round handle used to adjust the plate. It is hard to turn, I lubed the lead screws with bo-shield a light lubricant usually used for Alum. But is still very hard the turn handle. Not sure how hard this should be. And help will be appreciated.
Thanks RICK
It is probably dust..
I am no expert ,,,,so allow me to just ask a question,,,, when the table moves up and down ,,,,,it slides in a track on the ends,,, could they be full of dust ,,or even rust?
my dad has a planer that adjust the table with a chain when ya turn the crank handle, constant cleaning is a good thing.
good luck
Hobbyman2
Re: Everything Mark 5 / V - Technical info, documentation, links
It should turn quite easily.
I would be suspicious of the elevator(jack screws) sprockets being out of sync with each other. Have you checked the side to side/front to rear alignment to the cross bars?
